Re: bigger expansion pipes?
M-Tenn Aaron /
Hey Tyler, I think you could fit a 24mm Mikuni in there and still keep the cover on it. So far I think I have found out that the KH100 rotary valve will fit if you change out the bearings and oil seal on the valve side. It is a steel valve so supposed to be an upgrade for it. I wonder if the 100cc top end will bolt up with no problems ?
  bigger expansion pipes?Topic by: «tyler » «tyler » 05/08/11 01:57PM
  Re: bigger expansion pipes?Re: Ben Krenke Ben Krenke 05/08/11 02:02PM
  Re: bigger expansion pipes?Re: Epic Swoop Epic Swoop 05/08/11 02:21PM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 05/08/11 02:49PM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/09/11 11:23AM
  Re: bigger expansion pipes?Re: Cooper Hennick Cooper Hennick 05/09/11 11:48AM
  Re: bigger expansion pipes?Re: Sam Catalano Sam Catalano 02/21/12 06:15PM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/09/11 02:24PM
  Re: bigger expansion pipes?Re: Chris R Chris R 05/09/11 05:20PM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/09/11 06:32PM
  Re: bigger expansion pipes?Re: Epic Swoop Epic Swoop 05/09/11 07:04PM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 05/16/11 02:09AM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/16/11 11:43AM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 05/16/11 01:48PM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/16/11 02:17PM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 05/16/11 02:52PM
  Re: bigger expansion pipes?Re: M-Tenn Aaron M-Tenn Aaron 05/16/11 08:26PM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 05/16/11 08:59PM
  Re: bigger expansion pipes?Re: Nash . Nash . 02/21/12 06:17PM
  Re: bigger expansion pipes?Re: Salsa Salsa Salsa Salsa 02/21/12 06:59PM
  Re: bigger expansion pipes?Re: «tyler » «tyler » 02/21/12 08:51PM
  Re: bigger expansion pipes?Re: Better Fส็็็็็็็็็็็็็็็็ster Better Fส็็็็็็็็็็็็็็็็ster 02/22/12 01:04AM
