To check, run the bike without the airbox. If your ped starts running lean, you will know that the airbox is restrictive. Running lean means too much air, and too much air can cause it to bog. Do a plug chop to check though.
Subject | Written By | Posted |
TTLX had a loose main jet......Topic by: Garret | Garret | 01/28/02 03:47PM |
Re: TTLX had a loose main jet......Re: Crisis--Cincinnati | Crisis--Cincinnati | 01/28/02 05:24PM |
Re: TTLX had a loose main jet......Re: Crisis--Cincinnati | Crisis--Cincinnati | 01/28/02 05:31PM |
Re: TTLX had a loose main jet......Re: Ron Brown | Ron Brown | 01/28/02 07:31PM |
Re: TTLX had a loose main jet......Re: Crisis--cincinnati | Crisis--cincinnati | 01/28/02 08:35PM |
Re: TTLX had a loose main jet......Re: Reeperette | Reeperette | 01/29/02 03:09AM |
