TTLX had a loose main jet......
Garret /
finally got pissed & dropped the engine, tapped out the exhaust and carb bolt threads (cuz the factory tap job stank) and disassembled the carb. Lo and behold the main jet was loose and turning in its threads, cleaned it all out, tightened up the main jet, put it all back 2gether and it runs fine again.
I just tested compression on the bike (just bought a guage) and it read 85psi (6 kg/cm2) is that normal for an A3? cant find compression specs listed anywhere in the shop manual.
some1 also posted here about cutting the air box and adding a larger main jet for more power, does this really provide that much of an increase? (is it worthwhile?)
since i have a Dellorto on my A3 and parts are easy 2 get im up2 doin it.
  TTLX had a loose main jet......Topic by: Garret Garret 01/28/02 03:47PM
  Re: TTLX had a loose main jet......Re: Crisis--Cincinnati Crisis--Cincinnati 01/28/02 05:24PM
  Re: TTLX had a loose main jet......Re: Crisis--Cincinnati Crisis--Cincinnati 01/28/02 05:31PM
  Re: TTLX had a loose main jet......Re: Ron Brown Ron Brown 01/28/02 07:31PM
  Re: TTLX had a loose main jet......Re: Crisis--cincinnati Crisis--cincinnati 01/28/02 08:35PM
  Re: TTLX had a loose main jet......Re: Reeperette Reeperette 01/29/02 03:09AM
