turn signals
My stupid roomate dumped my bike this morning. The turn signal works when it is by itself but when you turn the headlight on too it just stays on very dim. It doesn't flash. What is this?
Re: turn signals
First don't lend your moped to your roomate. If you didn't and your roomate just knocked it over, have him stay in the garage and bring the moped indoors.
Could be a bad ground on the system. Try running a jumper from where the lamp should ground to a known good ground, like the engine block. If that works, then determine where the original ground failed and fix that.
Jim
Re: turn signals
power shortage
