deathly slow TTLX
my '90 TTLX (tomos) has now slowed down to about 10mph, the plug fouls and it eats exhaust gaskets 4 breakfast. what the heck is causing this?
by the way, i have a Biturbo, could it be the reason?
Re: deathly slow TTLX
Not the biturbo.
Had one on my 94 sprint since it rolled off the floor in 94 and never broke a seal.
Bizmarc
Reeperette /
Man, make sure the exhaust isn't clogged...cause that'll do it.
Also a stripped cylinder bolt will cause about the same trouble.
Those are only the two most likely, but worth a look.
-R
Hi All, the bi-turbo has a lot of little holes down at the packing, they do get clogged up, take the clip off and end cap,pull out the packing... its probaly nasty, then I drilled out the 3 pop rivets to remove the gold outter shell... there is the pipe with holes mabe 6in long... I had to use a drill bit to open mine back up... reverse procedure. You can buy the new oregeral type formed packing about $8. Check around for it, I know Heeters has it. Good Luck! Doug D.
Sprint Man /
Get the shop to inspect it. Tell them to check out your'e carberator, your pipe, and ask them if you need transmission fluid. You can also try getting a 26 or 27 toothed sprocket. You also might be using low quality oil. Make sure it's good oil and your'e adding correctly
