RE: Help! Leaded fuel?
Fred /
Your Puch is a 2 stroke ....Right?.....Then you DO NOT have to use leaded fuel....It will not make it run better... and YOU WILL NOT HURT YOUR MOTOR by running unleaded....that must be a pretty old moped to have that warning on there.....all 2-strokes (including highly tuned racing dirt bikes) run fine on unleaded... your moped probably also says to run the oil mix at 20 to 1 or 25 to 1 also.....that is also not necessary... with modern oils you can run it at 3 ounces of 2-stroke oil to 1 gallon of gas.... which is 43 to 1
  Help! Leaded fuel?Topic by: Nick Nick 08/13/00 05:31PM
  RE: Help! Leaded fuel?Re: scott scott 08/13/00 10:36PM
  RE: Help! Leaded fuel?Re: David Brook David Brook 08/13/00 10:53PM
  RE: Help! Leaded fuel?Re: Fred Fred 08/14/00 12:22AM
  RE: Help! Leaded fuel?Re: scott scott 08/14/00 10:01AM
  RE: Help! Leaded fuel?Re: dan dan 08/14/00 12:01PM
  RE: Help! Leaded fuel?Re: dave dave 08/15/00 03:04PM
  RE: Help! Leaded fuel?Re: Anthony Sperling Anthony Sperling 08/16/00 07:37AM
