RE: moped starting problems..
Fred /
First of all, have you tried a new spark plug?.....2nd... you know its a 2-stroke and you have to mix the gas with 2-stroke oil..right? .....Next... since you are mechanically inclined, go ahead and pull the head and cyl off and take a look at the piston and bore to see what kind of shape they are in.... because if you've got everything else, it could be low compression from old age or more likely a kid didn't use oil in the gas........lastly, if you have to get the flywheel off... a "pittman arm puller" for a car will sometimes work for getting it off.... can prolly rent it for $5...try that stuff and get back
  moped starting problems..Topic by: Michael Michael 08/11/00 11:10PM
  RE: moped starting problems..Re: Fred Fred 08/12/00 04:12AM
  RE: moped starting problems..Re: Michael Michael 08/12/00 03:31PM
  RE: moped starting problems..Re: Fred Fred 08/12/00 07:59PM
  RE: moped starting problems..Re: Ivo Ivo 08/12/00 10:32PM
  RE: moped starting problems..Re: Michael Michael 08/13/00 03:43AM
  RE: moped starting problems..Re: Fred Fred 08/13/00 05:23AM
  RE: moped starting problems..Re: Ivo Ivo 08/13/00 01:04PM
