Just got back from the garage trying to map out the wiring of my bike.. most of it makes sense but i'm somewhat confused when it comes to the brakelights. There's a spst switch with the cover missing (so i dont know what it does) and from what it looks like, it connects a ground to a ground...but that doesnt make any sense. what other switches might there be besides a headlight/horn switch on the handles? a kill switch perhaps? it also seems as if ground isnt the negative terminal of the battery but something else..is this true? One last thing, right above the rear wheel and below the seat is a little coil with a white wire sticking out. It's not currently connected to anything and the only wire i have that could connect is a wire i was assuming went to the positive terminal of the battery (a white wire). I assume the other end of the coil connects to ground. what on earth could this be? ANY help or comments would be appreciated... thnx.
