I've cleaned the exhaust on my mobylette and put it back on. When I start it, there's a sound of a quick burst of air that I think is coming from the exhaust. Is it the exhaust or is it something else ?
exhaust question
RE: exhaust question
I would look real carefully at the exhaust pipe to cylinder joint and make sure you got it all lined uo correctly....Lay the bike over on its side to get a good look at it.
What needs to be lined up ? It's a large gland nut that screws into the cylinder head.
I just thought it might not be re-installed correctly.... and be leaking air to make that noise........but if its made so you can't get it wrong then you don't need to check it.
