bi-turbo help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have a 1 piece bi-turbo its loose not by the exhaust port but by the where the gold ends and turns silver they look like allen screws that are loose and i have like every kind of allen key and none worked so can some one tell me how to tightin it and if it is an allen screw what size allen key is it
id really like some help
Jeff
Re: bi-turbo help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hello, the ones I have had apart use pop rivets, I drill them out and put new ones back in. Doug D.
Reeperette /
This is a guess mind....but 4.2mm
(Cause I've run into this size before)
Good fergin luck finding a 4.2mm hex key - and US Sizes wont fit it neither.
Only way I know to turn those is to use a 4mm hexkey and a sliver or two of shim material, verrrry cautiously.
Or...get a 5mm and hone it down to 4.3mm and use a hammer on the damned thing, which is not exactly the reccommended way to do it - but it does tend to get the damn things out so they can be replaced with fasteners made by SANE people.
Hexhead bolts are EVIL, spawn of the abyss.
-R
dumb & ugly /
cut the sucker of with an angle grinder &weld together a strait pipe for it no nuts,no bolts, no god forsaken 4.3 whatever the hell it is size anymore
There you go on that Percussive Maintenance again,Ree!
thanks for all your help
