I've got a mobylette and the brake light works but the light that should be on constantly does not. I took the lens off and there's a small bulb with a larger bulb on top of it. Is this just a bad bulb or is it the wiring ? Can you get replacement bulbs anywhere or do they have to be specifically for mopeds ?
tail light
RE: tail light
The only thing special about it is the voltage, you need either a 6 or a 12 volt bulb, motobecanes used either a 12 or a 6 depending on what year it was. it sounds to me like a bad bulb. you can get a replacement at a hardware store. just take it in with you.
dan
RE: tail light
Thanks dan !
