Re: Time between
Ron Brown /
Scott,
Read all these posts again.
Fred's looks good because it has a good chance of pointing at, or eliminating, the gas supply to the carb which is the subject of many of the other posts..
A plugged gas tank cap might cause a problem but as soon as you take the cap off and replace it, it will run a lot longer before it dies the first time. This makes this problem unlikely but Fred's test will show it.
Fred's test will also show a problem with the float and needle valve.
You may still have an ignition problem. If your ignition is electronic, it could be temparature sensitive, if points, you could have a bad capacitor.
Do Freds tes and if it points you to the problem, you are good to go. If it does not, check spark and repost.
Ron
  cranks, idles, runs for a sec, dead.Topic by: Scott Scott 01/06/02 03:51PM
  Re: cranks, idles, runs for a sec, dead.Re: Zippy Zippy 01/06/02 04:11PM
  Re: cranks, idles, runs for a sec, dead.Re: Ron Brown Ron Brown 01/06/02 05:08PM
  Re: cranks, idles, runs for a sec, dead.Re: Ryan J Ryan J 01/06/02 05:20PM
  Time betweenRe: Scott Scott 01/06/02 06:07PM
  Re: Time betweenRe: Fred Fred 01/06/02 06:26PM
  Re: Time betweenRe: Zippy Zippy 01/06/02 10:47PM
  Re: Time betweenRe: Scott Scott 01/06/02 10:49PM
  Re: Time betweenRe: RogNC RogNC 01/07/02 05:07AM
  Re: Time betweenRe: Scott Scott 01/07/02 09:36AM
  Re: Time betweenRe: Ron Brown Ron Brown 01/07/02 12:03PM
