Re: motobecane plug and tank cleaning..
Zippy /
If it is really bad I would recommend using Creem. Be sure and follow the mfg instructions and don't get this stuff on the paint. You only need to use half the kit as it is designed for motorcycle tank capacities. Be sure and let the Creem dry before you put gas/oil mix in the tank
