Re: Bat spark plug wire
Ron Brown /
Rob,
I have not bothered to look at mine, but if you see what looks like the sharp end of a brass wood screw when you look into the end of the coil, this is a typical installation. You should use stranded copper plug wire and if the wire gets loose at the coil and you have enough slack, cut off about 1/4" from the end of the wire and then screw it back in.
Ron
  Bat spark plug wireTopic by: Rob Rob 01/05/02 03:34PM
  Re: Bat spark plug wireRe: Ron Brown Ron Brown 01/05/02 03:44PM
  Re: Bat spark plug wireRe: InfectedBootSector InfectedBootSector 01/05/02 04:20PM
  Re: Bat spark plug wireRe: duck duck 01/05/02 11:10PM
  I am using an 8mm wireRe: duck duck 01/05/02 11:12PM
  Re: Bat spark plug wireRe: Reeperette Reeperette 01/06/02 12:21AM
