i painted it
check it out i painted it back to the original color
Re: i painted it
whoops sorry about that
i have one more question
what is this thing. it was sparking when i was running it so i bolted it down figured it was shorting. Now the lights wont work? please help.
Re: i painted it
Crisis--Cincinnati /
You need some side covers and you will be good to go, except for the lights not working. Looks pretty good!
Re: i have one more question
Ron Brown /
David,
Looks like a rectifier. Do you have a battery?
Ron
no i dont , with this item should i? what is your advice to remedy this problem
Ron Brown /
> remedy this problem
David,
Was the ped originally equipped with a battery?
Ron
when i bought it from that yard sale it wasnt equipped with one. did motobecane release mopeds with batteries? is this a custom piece ?? maybe i should remove it.
Ron Brown /
David,
This is tough to do without seeing the ped.
Every answer raises a question and needs a clear answer. I am not asking if the ped has a battery in it, I am asking if it ever did. As in, is there a place on the ped where one used to live, perhaps a couple of terminals hanging around with no place to connect to? I think you have told me no, but your answers leave a question mark. : )
What model of Motobecane is it?
How many wires and what colors go to this device?
Does the device look like an original installation or something Wayne would have done? : )
Ron
well there is only one welded wire going to this device and that wire goes inside the light housing. if come one had a battery on it at one point i dont know how they would have done it there is no indication that such is true. it is a motobecane "1976" V.in my second response in this topic i included a picture of the ped. I dont think it is original (because the wire being welded on)but that was one of the things i was inquiring with this topic.
dave
Ron Brown /
David,
If it only ever had one wire, It is unlikely to be a rectifier.
I am more confused now, maybe someone with a wiring diagram for your ped can identify it.
Can you open the headlamp and figure out what the wire is fastened to?
Ron
mike hartel /
its a volttege regulater
Ron Brown /
Without a battery?
