i have a 1990 TTLX
Garret /
ive got a black 1990 TTLX & the thing runs like a top. yours has a late model A3 engine, its the older design of tomos engine but fortunate for you yours has the newer type italian Dell'Orto carb like mine. the old Encarvi carbs all the older models had are no longer made, the dellorto 14/12SHA in yours is, so parts for it are still easy to get. I dont know how that bike will handle your weight (no offense) however it is the largest of the tomos 50cc's that was imported to the US at the time, so u may be ok, im only 5'3" 130lbs, so i cant help ya there. I installed a biturbo pipe and electronic ignition on mine, all tomos' up until 1992 had points, but stick with them, the CDI does nothing for performance, and it is difficult to install, only switch if you are gonna use the 'ped as your ONLY means of transportation (like i do) otherwise it aint worth it.
i attached a pic of my 'ped minus the engine & it was in my basement (puttin it back 2gether). I have almost no complaints about it, its a solid machine & amazes me every time it starts with 2 kicks in 30degree cold (choked of course).
By the way, if your choke lever locks down, "flooring" the throttle will pop it open, first time i got my bike i dropped the engine thinking id jammed somthing in the carb.
ok ok, ill shut up (WAY 2 much caffine!!)
  1991 tomas golden bullet tt lxTopic by: paul paul 12/31/01 08:50PM
  Re: 1991 tomas golden bullet tt lxRe: Crisis Crisis 01/01/02 02:34AM
  Re: 1991 tomas golden bullet tt lxRe: paul paul 01/01/02 10:48AM
  Re: 1991 tomas golden bullet tt lxRe: Crisis Crisis 01/01/02 04:47PM
  Re: 1991 tomas golden bullet tt lxRe: Dave Dave 01/01/02 11:45AM
  Re: 1991 tomas golden bullet tt lxRe: Wayne Wayne 01/01/02 05:19PM
  i have a 1990 TTLXRe: Garret Garret 01/02/02 02:16AM
  Re: i have a 1990 TTLXRe: jeff jeff 01/02/02 09:22PM
  Well spoken, All.Re: Reeperette Reeperette 01/02/02 03:33PM
  HEY REE!!!!!!!!!!!!!Re: paul paul 01/05/02 10:11PM
