Weird problem
My friend has a tomos and for some reason when try to start the moped it takes a lot more tries to get it started when the lights are off...and sometimes when you turn the lights off..the moped dies...any ideas?
Re: Weird problem
so if it works ok with the lights on, why not leave them on???
Re: Weird problem
Reeperette /
You might have a short, or faulty wiring in the tail light system, or the turn signals - that is the usual cause of this problem.
But not always.
Use a continuity tester to see if you can narrow it down.
-R
