points
how often do you change the points in a moped?
RE: points
If they look good I never change them.....I do try to clean and adjust them once a year.......I like to clean them by taking them out and take a piece of 400 grit sandpaper....open the points....lay the sandpaper in between them.... let the points close....then pull the sandpaper through.......do this 3 or 4 times for each pad.... then use aerosol carburetor cleaner or brake cleaner and squirt them while holding the points open...then let them dry and re-install them and set the point gap correctly..........
RE: points
thanks
