Also true! When you switch off a Motobecane, you switch the horn on. It then blows continuously at engine rpm until the engine stops. Best imitation of the AFLAC duck in distress I ever heard. : )
I think the idea is to warn you that the switch is off when you try to start it. It may also be a marketing ploy as everyone within hearing range turns and looks when you turn it off.
