I am a great source of misinformation
Ryan J /
I never stated that the oil injection in snowmobiles was to the bearings. You must have imagined that.
you are right about floating valves- but I have had valves stick and I've had valves burn. A freind of mine has had a valve swallowed by the engine (but this was on a very old car) And I've done many valve jobs.
You probably didn't bother looking up the lubrication system used on the Subaru 360 either.
I still don't know what point you are arguing but it probably has nothing to do with what power source is better for mopeds.
And as I stated modern 2-cycle engine using oil injection to the bearings really has nothing to with being new except that it is faw newer than the concept of mixing gas with oil on those simple single cylinder jobs. Maybe I should have classified them as complex and simple engines.
I am sorry for missleading you.
  the power dispute.Topic by: Ryan J Ryan J 12/28/01 06:04PM
  Re: the power dispute.Re: Jim C Jim C 12/28/01 07:19PM
  There is no dispute (over power)Re: Fred Fred 12/29/01 12:36AM
  Re: There is no dispute (over power)Re: Ryan J. Ryan J. 12/29/01 02:33AM
  Name a 2 stroke with "pressure lubed" brRe: Fred Fred 12/29/01 11:22AM
  spota read "pressure lubed" bearingsRe: Fred Fred 12/29/01 11:24AM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:50PM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:56PM
  Re: spota read "pressure lubed" bearingRe: Ron Brown Ron Brown 12/29/01 03:06PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ryan J. Ryan J. 12/29/01 03:10PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ron Brown Ron Brown 12/29/01 03:21PM
  You are a great source of misinformationRe: Fred Fred 12/29/01 06:16PM
  I am a great source of misinformationRe: Ryan J Ryan J 12/29/01 09:07PM
  You sure are.Re: Fred Fred 12/30/01 11:00AM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 11:51AM
  Re: You sure are.Re: Fred Fred 12/30/01 01:02PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 01:10PM
  aaaaahahahaha!Re: Fred Fred 12/30/01 02:05PM
  Re: aaaaahahahaha!Re: Ron Brown Ron Brown 12/30/01 02:17PM
  Re: You sure are.Re: Ryan J Ryan J 12/30/01 05:26PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 06:20PM
  Re: You are a great source of misinformationRe: Ryan J Ryan J 12/30/01 05:31PM
  Re: You are a great source of misinformationRe: Ron Brown Ron Brown 12/30/01 06:23PM
  the pressure is tooooo muchRe: Fred Fred 12/30/01 06:32PM
  Re: the pressure is tooooo muchRe: Wayne Wayne 12/30/01 06:38PM
  Re: the pressure is tooooo muchRe: Ryan J Ryan J 12/30/01 06:59PM
  Re: the pressure is tooooo muchRe: Ike Ike 01/01/02 06:23PM
  because its better than thatRe: Fred Fred 01/01/02 07:14PM
  Re: the power dispute.Re: Ron Brown Ron Brown 12/29/01 12:11PM
  lotta confusionRe: Fred Fred 12/29/01 01:41PM
  Re: lotta confusionRe: Ron Brown Ron Brown 12/29/01 01:51PM
  VESPA ET2 IniezioneRe: Ron Brown Ron Brown 12/29/01 02:39PM
  Re: the power dispute.Re: gimmyjimmy gimmyjimmy 12/29/01 06:34PM
  Re: the power dispute.Re: Ryan J Ryan J 12/29/01 09:08PM
  Re: the bottom line!!!Re: Ike Ike 01/01/02 06:33PM
