You are a great source of misinformation
Fred /
> Try going to: http://www.suzukicycles.com/faq/tcheng19.htm
> For a short description of CCI which stands for
> Crankcase-cylinder-injection.
No... You go there and read whatever you want... I know more about those things than you will by reading whatever it is you want to read.
Pressure lubed bearings means the oil is supplied under pressure.. those old CCI Suzuki's don't develop any pressure... they used Mikuni manufactured oil pumps that "trickled" the oil in.
So they are NOT "pressure lubricated bearings"
And.... In case you didn't know it... those 2 stroke Suzuki motorcycles were discontinued 20 to 25 years ago.... Real modern.
>Some modern 2-cycle snowmobiles also come with this (oil injection).
Oh my... Wrong again... all modern snowmobiles and jet skis come with oil injection... but it is NOT injected to the bearings.
It is tricked into the intake tracts... not even squirted... it just oozes out of a hole.
The airstream pushes it towards the spinning crank... where it gets blown off/drips into the crank... quite crude... but proven effective none the less.
> And vavles are the weakest part of the system- at high speeds
> they float causing backfiring and loss of power they can also
> stick open or closed, they can burn or be swallowed by the
> engine causing lots of damage- if made slightly wrong they
> leak (which in turn leads to them burning...again)
blah blah blah.... Right... good theory.. but in truth 4 strokes are about the most reliable engines there are.. thats why they get used for almost everything
And... you've never floated the valves on anything in your life... you read it in a book.
I also bet you've never held a 4 stroke valve in your hand in your life.
I bet you don't even have a drivers license.
> Have you ever owned a moped or motorcycle or snowmobile or
> outboard motor boat . If you've owned all of these then you
> certainly have owned more than I have.
  the power dispute.Topic by: Ryan J Ryan J 12/28/01 06:04PM
  Re: the power dispute.Re: Jim C Jim C 12/28/01 07:19PM
  There is no dispute (over power)Re: Fred Fred 12/29/01 12:36AM
  Re: There is no dispute (over power)Re: Ryan J. Ryan J. 12/29/01 02:33AM
  Name a 2 stroke with "pressure lubed" brRe: Fred Fred 12/29/01 11:22AM
  spota read "pressure lubed" bearingsRe: Fred Fred 12/29/01 11:24AM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:50PM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:56PM
  Re: spota read "pressure lubed" bearingRe: Ron Brown Ron Brown 12/29/01 03:06PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ryan J. Ryan J. 12/29/01 03:10PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ron Brown Ron Brown 12/29/01 03:21PM
  You are a great source of misinformationRe: Fred Fred 12/29/01 06:16PM
  I am a great source of misinformationRe: Ryan J Ryan J 12/29/01 09:07PM
  You sure are.Re: Fred Fred 12/30/01 11:00AM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 11:51AM
  Re: You sure are.Re: Fred Fred 12/30/01 01:02PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 01:10PM
  aaaaahahahaha!Re: Fred Fred 12/30/01 02:05PM
  Re: aaaaahahahaha!Re: Ron Brown Ron Brown 12/30/01 02:17PM
  Re: You sure are.Re: Ryan J Ryan J 12/30/01 05:26PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 06:20PM
  Re: You are a great source of misinformationRe: Ryan J Ryan J 12/30/01 05:31PM
  Re: You are a great source of misinformationRe: Ron Brown Ron Brown 12/30/01 06:23PM
  the pressure is tooooo muchRe: Fred Fred 12/30/01 06:32PM
  Re: the pressure is tooooo muchRe: Wayne Wayne 12/30/01 06:38PM
  Re: the pressure is tooooo muchRe: Ryan J Ryan J 12/30/01 06:59PM
  Re: the pressure is tooooo muchRe: Ike Ike 01/01/02 06:23PM
  because its better than thatRe: Fred Fred 01/01/02 07:14PM
  Re: the power dispute.Re: Ron Brown Ron Brown 12/29/01 12:11PM
  lotta confusionRe: Fred Fred 12/29/01 01:41PM
  Re: lotta confusionRe: Ron Brown Ron Brown 12/29/01 01:51PM
  VESPA ET2 IniezioneRe: Ron Brown Ron Brown 12/29/01 02:39PM
  Re: the power dispute.Re: gimmyjimmy gimmyjimmy 12/29/01 06:34PM
  Re: the power dispute.Re: Ryan J Ryan J 12/29/01 09:08PM
  Re: the bottom line!!!Re: Ike Ike 01/01/02 06:33PM
