Re: There is no dispute (over power)
Ryan J. /
"modern" 2-cycle engines are very clean buring compared to their simple and older counterparts. What I would classify as a modern 2-cycle is nearly any engine with a self metering oil injection system- these systems lubricate the engine better and with less oil and less smoke than mixing the oil with the gas. Not to mention far less carbon build up. Also because the bearings in these systems are pressure lubricated more power can be made. I think 2-cycle engines are better than 4-cycles in nearly every respect but 4-cycle engines still have advantages over 2 strokers. And with new technology 4-cycle engine are making more power. But the 4-cycle engine weakest point has been with it since the begining and that would be valves- which can leak or become burnt and suffer from many other dissorders.
  the power dispute.Topic by: Ryan J Ryan J 12/28/01 06:04PM
  Re: the power dispute.Re: Jim C Jim C 12/28/01 07:19PM
  There is no dispute (over power)Re: Fred Fred 12/29/01 12:36AM
  Re: There is no dispute (over power)Re: Ryan J. Ryan J. 12/29/01 02:33AM
  Name a 2 stroke with "pressure lubed" brRe: Fred Fred 12/29/01 11:22AM
  spota read "pressure lubed" bearingsRe: Fred Fred 12/29/01 11:24AM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:50PM
  Re: spota read "pressure lubed" bearingRe: Ryan J. Ryan J. 12/29/01 02:56PM
  Re: spota read "pressure lubed" bearingRe: Ron Brown Ron Brown 12/29/01 03:06PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ryan J. Ryan J. 12/29/01 03:10PM
  Re: Name a 2 stroke with "pressure lubed&quotRe: Ron Brown Ron Brown 12/29/01 03:21PM
  You are a great source of misinformationRe: Fred Fred 12/29/01 06:16PM
  I am a great source of misinformationRe: Ryan J Ryan J 12/29/01 09:07PM
  You sure are.Re: Fred Fred 12/30/01 11:00AM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 11:51AM
  Re: You sure are.Re: Fred Fred 12/30/01 01:02PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 01:10PM
  aaaaahahahaha!Re: Fred Fred 12/30/01 02:05PM
  Re: aaaaahahahaha!Re: Ron Brown Ron Brown 12/30/01 02:17PM
  Re: You sure are.Re: Ryan J Ryan J 12/30/01 05:26PM
  Re: You sure are.Re: Ron Brown Ron Brown 12/30/01 06:20PM
  Re: You are a great source of misinformationRe: Ryan J Ryan J 12/30/01 05:31PM
  Re: You are a great source of misinformationRe: Ron Brown Ron Brown 12/30/01 06:23PM
  the pressure is tooooo muchRe: Fred Fred 12/30/01 06:32PM
  Re: the pressure is tooooo muchRe: Wayne Wayne 12/30/01 06:38PM
  Re: the pressure is tooooo muchRe: Ryan J Ryan J 12/30/01 06:59PM
  Re: the pressure is tooooo muchRe: Ike Ike 01/01/02 06:23PM
  because its better than thatRe: Fred Fred 01/01/02 07:14PM
  Re: the power dispute.Re: Ron Brown Ron Brown 12/29/01 12:11PM
  lotta confusionRe: Fred Fred 12/29/01 01:41PM
  Re: lotta confusionRe: Ron Brown Ron Brown 12/29/01 01:51PM
  VESPA ET2 IniezioneRe: Ron Brown Ron Brown 12/29/01 02:39PM
  Re: the power dispute.Re: gimmyjimmy gimmyjimmy 12/29/01 06:34PM
  Re: the power dispute.Re: Ryan J Ryan J 12/29/01 09:08PM
  Re: the bottom line!!!Re: Ike Ike 01/01/02 06:33PM
