amal carb???
chuck russo (VA) /
i have been thinking about buying one for my 87 tomos top tank,
is it worth it? how much faster will i go? will it increase acceleration? and what do they usally cost?
Re: amal carb???
okay, im sorry.. but i swear that said "anal carb".
Re: amal carb???
tomos did use both dellorto and amal carbs at different times, from what i know. i don't think either would make a difference, unless they are different sizes. what size/type carb do you have now? what size is the amal you are looking at buying?
Re: amal carb???
chuck russo (VA) /
i have a stock carb i think the amal carb i was looking at is 3 mm bigger
Re: amal carb???
what size carb do you have currently? what size is the new one?
a larger carb will give you more power for sure. how much depends on other things you do. you might want to get a larger manifold (you may need to). also check on performance exhausts (biturbo is common on tomos). there are a few other gearing things to get more top speed (though usually at a loss of acceleration).
but a larger carb is worth it if you can afford it and want another 5mph or so.
Re: amal carb???
No, I think it said something much more painful... Anal Crab :)
