RE: Worn clutch plate
Ivo /
Are you sure your ped has a plate-clutch? It looks like a ped with a block-clutch. You should try if the Vespa Ciao/Piaggio clutch fits, it's very cheap and it's easy to install or renew the blocks on it. An alternative to a clutch is a variator, it gives lots of extra power but is expensive. If your ped does have a plate-clutch it may be a good idea to check out Kreidler and Zundapp, these are very good German mopeds. Kreidler even has the speed world record with 50cc's.
  Worn clutch plateTopic by: chris chris 07/13/00 05:03PM
  RE: Worn clutch plateRe: Ivo Ivo 07/14/00 07:16PM
  RE: Worn clutch plateRe: chris chris 07/14/00 08:31PM
  RE: Worn clutch plateRe: Ivo Ivo 07/16/00 09:39PM
