When buying a 60cc/70cc upgrade kit, do you HAVE to buy the pipe with it, even if you already have a biturbo?
Unless you want to heat and bend the pipe you have, yes.
What kind of moped are you upgrading?
Puch Maxis have flat exhaust manifold connections.
The exhaust connection on the Puch Magnum cylinder is slanted.
The upgrade kits cylinder connection is for a flat design. If your Bi Turbo connection is flat and not slanted you shouldn't have to buy a new Bi Turbo.
