Re: What is the best way to save a rusty chain?
miguel /
how "rusty" is it? i'd guess just clean it and let it soak in something to clean it, then use some chain lube or chain grease. it should be ok after that.
try something like wd40 or even carb cleaner ... maybe a wire brush on it ... then maybe let it soak overnight in some gasoline.
unless you get a better suggestion ...
