Correct Mix...
Shane Wolfe /
Ok. I'm trying to straighten this out. I should use a 20:1 Mixture of 2 cycle oil in my 78 Puch Maxi....? I read 50:1 in the Manual, but 20:1 on the bike.
RE: Correct Mix...
I typically run a 44:1 mix in my moped... although I've seen recommendations anywhere from 25:1 to 50:1.
_wal
RE: Correct Mix...
Reeperette /
I would suggest erring on the side of caution.
Better too much than too little.
Cleaning or replacing a fouled plug is much easier than replacing chewedup piston and cylinder.....believe it.
Ree.
RE: Correct Mix...
Simon King /
it's all about experimentation to find your best mix - and it's different with each oil. but i agree with Reeperette - err to the side of caution.
