Tomos Targa LX Speed Kit
<HTML>Well I have been reading some of the topics about how the speed kits mess up stuff, and i just ordered one the other day. Now I am scared about it breaking. Well, hopefully I won't have any trouble.
</HTML>
RE: Tomos Targa LX Speed Kit
<HTML>Just "break it in" carefully.......when you get done installing it, start it up and run it slowly for 10 minutes and shut it off and let it cool off for 30 minutes........then do that two more times.......slowly........then you can start running it more like normal........but you should still wait till you run it another 30 minutes before you try to see how fast it will go.........otherwise it could seize.......</HTML>
<HTML>Oh yeah.......when you are installing it .......make sure you smear 2 stroke oil on the new piston and inside the cylinder before you put the cylinder back on........and make sure the ring ends lines up with the little pin inside the piston ring groove</HTML>
