I like to put the 2 stroke in the gas can first, then poor the gas in from the pump. It gets mixed really nicely. Sounds like you just need to clean your carb. You probably have something blocking the jet (little brass screw with small hole in the middle, found when you take the bowl off of the carb) Hope this helps!
Chris
