Re: Rectyfier
Ron Brown /
Oliver,
I am having a hard time typing this between laughng at the stupid responses, like yours, crying over the fact that someone can make it through high school knowing so little about electricity and laughing at the amusing responses from the few who understand.
In the spirit of the moment, I will now grade this thread. : )
>Author: paul (---.proxy.aol.com)
>Date: 12-11-01 15:59
>hi all, at jcwhitney.com they have a 6volt horn for sale. would this work on 6volt >peds??
Oliver, if you are so smart, why did you ask this question? You knew your "ped" was 6v dc, you knew cars and motorcycles use dc. The only problem you could have is a battery, or horn wiring which can't handle the horn current.
Next time you post, tell us something about the "ped" like how mant wheels it has, this will probably get you better answers.
>Author: Ron Brown (---.ismi.net)
>Date: 12-11-01 16:19
>Paul,
>Most peds are AC, most horns for other applications are DC and will not work >correctly.
This post, of course, is perfect. Don't argue with me! I am doing the grading here!
>Author: oliver (---.client.attbi.com)
>Date: 12-11-01 19:14
>are you on drugs???? ALL mopeds are DC the only part that is ac is the >ignitionsystem, then a silicon rectifyer changes it to dc. for lamps, horns, etc...
Oliver, if you can come out of your drug induced haze just long enough for some enlightenment; this is a Moped Forum Mo(Motor)-Ped(Pedals), if you are posting about some other type of vehicle, please say so and avoid all the confusion. If it is 50cc you will probably get an answer even if it is a scooter. You have described a scooter electrical system fairly well, pity you asked your question about a moped. Almost all mopeds have no rectifier or battery and run everything on ac at 6 or 12 volts.
>Author: miguel (---.dsl.gdrpmi.ameritech.net)
>Date: 12-11-01 20:10
>mopeds (as opposed to scooters) don't even have ignition systems.
Miguel!!! Read before you post! I am sure you meant to say "charging" instead of ignition, otherwise, if your spark plug simply prevented compression loss, why would it have to be platinum? : )
  horn!!Topic by: paul paul 12/11/01 04:59PM
  Re: horn!!Re: Ron Brown Ron Brown 12/11/01 05:19PM
  Re: horn!!Re: oliver oliver 12/11/01 08:14PM
  Re: horn!!Re: miguel miguel 12/11/01 09:10PM
  Re: RectyfierRe: Ron Brown Ron Brown 12/12/01 11:16AM
  Re: RectyfierRe: Ron Brown Ron Brown 12/12/01 11:47AM
  Re: horn!!Re: Ron Brown Ron Brown 12/12/01 11:50AM
  You're wrong.. electrics run on smoke pressure.Re: Fred Fred 12/13/01 12:11AM
  Re: You're wrong.. electrics run on smoke pressureRe: miguel miguel 12/13/01 12:25AM
  Re: You're wrong.. electrics run on smoke pressureRe: Ron Brown Ron Brown 12/13/01 12:34AM
  Re: RectyfierRe: Jim C. Jim C. 12/11/01 09:28PM
  Re: RectyfierRe: oliver oliver 12/11/01 09:33PM
  Re: RectyfierRe: Wayne Wayne 12/12/01 09:02AM
  Re: RectyfierRe: Crisis Crisis 12/12/01 10:13AM
  Ignition.Re: Reeperette Reeperette 12/12/01 05:40PM
  Re: Ignition.Re: miguel miguel 12/12/01 10:40PM
  Re: Ignition.Re: miguel miguel 12/12/01 10:50PM
  terminilogyRe: Fred Fred 12/12/01 11:00PM
  Re: terminilogyRe: miguel miguel 12/12/01 11:34PM
  Re: terminilogyRe: Fred Fred 12/13/01 12:03AM
  RE: Moped ElectricalRe: Wayne Wayne 12/13/01 06:09PM
  RE: Moped ElectricalRe: todd todd 12/14/01 10:04AM
  RE: Moped ElectricalRe: don-ohio don-ohio 12/14/01 11:15AM
