<HTML>You cant get the inside of a carb loose, it's made out of one piece. You can take the following parts off of it:
- The gaschamber
- The jet(s)
- The throttlestopscrew and airscrew (if that carb has an airscrew)
- The throttleslide (wich is jammed in your carb)
Normally if you want to take out the throttleslide you unscrew the top of the carb and simply pull out the throttleslide. On some carbs the slide will be jammed if the choke is on.</HTML>
