Re: Engine mounting?
Jim C. /
Brandon:
I'm thinking that maybe your engine's position can be shifted. Also be sure that rear mounting bolt is in the right hole, which is the one with a reinforcement plate. The one below the visible hole in the picture is the correct one.
You can safely try to shift the engine's position by loosening the muffler's attachment bolt, not the pipe clamp, and the two long front bolts and the single bolt we have been referring to.
Slip. slide, twist the engine to see if there is a better position for the brake cable.
If one is found, tighten all those bolts back up again and you're through. no wires or cables need to be disconnected to do this.
Jim
  Vespa Grande Airbox vs. Brake CableTopic by: XBrandon EdgeX XBrandon EdgeX 12/02/01 08:06PM
  Re: Vespa Grande Airbox vs. Brake CableRe: Jim C. Jim C. 12/02/01 09:00PM
  Re: Vespa Grande Airbox vs. Brake CableRe: XBrandon EdgeX XBrandon EdgeX 12/02/01 09:19PM
  Re: Vespa Grande Airbox vs. Brake CableRe: XBrandon EdgeX XBrandon EdgeX 12/02/01 11:38PM
  Re: Vespa Grande Airbox vs. Brake CableRe: XBrandon EdgeX XBrandon EdgeX 12/02/01 11:39PM
  Re: Vespa Grande Airbox vs. Brake CableRe: XBrandon EdgeX XBrandon EdgeX 12/02/01 11:40PM
  Gilera air boxesRe: Chris Stephens Chris Stephens 12/03/01 11:47AM
  Re: Gilera air boxesRe: XBrandon EdgeX XBrandon EdgeX 12/03/01 07:33PM
  Re: Cable RoutingRe: Jim C. Jim C. 12/03/01 07:03PM
  Re: Cable RoutingRe: XBrandon EdgeX XBrandon EdgeX 12/03/01 07:32PM
  Re: Gilera air boxesRe: Jim C. Jim C. 12/03/01 10:36PM
  Re: Gilera air boxesRe: XBrandon EdgeX XBrandon EdgeX 12/03/01 11:07PM
  Re: Engine mounting?Re: Jim C. Jim C. 12/04/01 07:25PM
