<HTML>I have a 1982 Eagle III (which is also called a Sachs G3) with a Sachs 501/ID motor. What is the correct oil for the transmission?
Thanks,
Paul</HTML>
Thanks,
Paul</HTML>
You need to use type F automatic transmition fluid. Hope this helps.
Chad
i have a 1992 sachs mopet, i need to know the correct transmission fluid. the engine is a sachs 505 series. thank you
