how do you attach a tach to a tomos
hi, i m=have a tomos sprint and got a tach, how do i attach it to my moped, the tach has 3 connectors and is ment for single cyclinders the first is ground, i know where that goes and there is power or positive, i know where that one goes but there is another, signal, where should i put this one? the spark plug wire?
Re: how do you attach a tach to a tomos
You know how to hook up the pos. and neg. the other one should tap into the points wire. Doug D
yes but i have cd ignition
Ron Brown /
Oli,
I'm not sure where to attach the signal wire, but unless your Tomos has a battery, all your power is AC which will most likely fry the tach.
Ron
