Re: 88 TOMOS
Mark P /
Okay, Well, I took off the air filter completely, cleaned and reexamined the carb and it still did the same thing. So I'm guessing it isn't an air/fuel mix problem. Still sounds starved and runs rough. I'm next going to try and find a Bosch replacement plug and pull out the exhaust. (BTW when I take the nuts off under the cylinder block for the exhaust, will I be loosing up something inside the block or are those bolts there to stay like the cylinder head bolts?) Then I'll try don-ohio's suggestion and spray some carb cleaner around the joints. If I still don't notice any improvement then I give up. I really want to avoid taking the WHOLE engine apart. I guess I'll take it to a shop and pay $200 to get a $50 moped working. - something I was hoping to avoid....oh well.
  88 TOMOSTopic by: Mark P Mark P 11/26/01 01:39PM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/26/01 01:44PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 01:58PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:11PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 02:16PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:32PM
  Re: 88 TOMOSRe: RogNC RogNC 11/26/01 09:31PM
  Re: 88 TOMOSRe: XBrandon EdgeX XBrandon EdgeX 11/26/01 04:30PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 04:51PM
  Tomos Baffle RemovalRe: Reeperette Reeperette 11/26/01 05:03PM
  Re: Tomos Baffle RemovalRe: Mark P Mark P 11/27/01 09:16AM
  Cylinder IssuesRe: Reeperette Reeperette 11/27/01 11:59AM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 12:06PM
  LoctiteRe: Reeperette Reeperette 11/27/01 05:28PM
  Re: LoctiteRe: don-ohio don-ohio 11/27/01 05:36PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 01:20PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:29PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:33PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 03:38PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 03:54PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:00PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:20PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:22PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:44PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 05:10PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 05:31PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 09:09AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 10:54AM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:23AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 12:15PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:26AM
  Re: 88 TOMOSRe: Reeperette Reeperette 11/28/01 12:50PM
