Loctite
Reeperette /
>>How `bout some loctite on that Ree?I'm getting ready to install a 60cc kit and I was gonna use some good loctite.Also,do you retighten when you have to use a composite gasket with metal sealing ring?<<
I dunno offhand about retightening, but I would reccommend against using loctite on the cylinder bolts.
Those are steel studs, threaded at both ends, that those nuts go onto, and at the bottom they are threaded into the soft aluminum of the transmission casing, practically BEGGING to be stripped, I consider that to be the greatest Tomos design flaw, actually.
You loctite them, you run the risk of tearing up the threads on the bottom if you ever have to get them off.
-R
  88 TOMOSTopic by: Mark P Mark P 11/26/01 01:39PM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/26/01 01:44PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 01:58PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:11PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 02:16PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:32PM
  Re: 88 TOMOSRe: RogNC RogNC 11/26/01 09:31PM
  Re: 88 TOMOSRe: XBrandon EdgeX XBrandon EdgeX 11/26/01 04:30PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 04:51PM
  Tomos Baffle RemovalRe: Reeperette Reeperette 11/26/01 05:03PM
  Re: Tomos Baffle RemovalRe: Mark P Mark P 11/27/01 09:16AM
  Cylinder IssuesRe: Reeperette Reeperette 11/27/01 11:59AM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 12:06PM
  LoctiteRe: Reeperette Reeperette 11/27/01 05:28PM
  Re: LoctiteRe: don-ohio don-ohio 11/27/01 05:36PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 01:20PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:29PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:33PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 03:38PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 03:54PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:00PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:20PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:22PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:44PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 05:10PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 05:31PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 09:09AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 10:54AM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:23AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 12:15PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:26AM
  Re: 88 TOMOSRe: Reeperette Reeperette 11/28/01 12:50PM
