Re: Cylinder Issues
Ron Brown /
Mark,
Use a sheet of fine wet or dry paper on a sheet of flat glass. Wet it, and rub the head in a circular motion on the wet or dry. If the head is flat, you will get an even flat finish on the head. Make sure you wash it well after ginding. Loctite makes a flexible, high temp joint material that I have used for heads and seems to work well. Unfortunately, I cant find the tube but most auto parts carry it. If it helps, the torque for Motobecabe head bolts is 9 ft/lbs.
Ron
  88 TOMOSTopic by: Mark P Mark P 11/26/01 01:39PM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/26/01 01:44PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 01:58PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:11PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 02:16PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:32PM
  Re: 88 TOMOSRe: RogNC RogNC 11/26/01 09:31PM
  Re: 88 TOMOSRe: XBrandon EdgeX XBrandon EdgeX 11/26/01 04:30PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 04:51PM
  Tomos Baffle RemovalRe: Reeperette Reeperette 11/26/01 05:03PM
  Re: Tomos Baffle RemovalRe: Mark P Mark P 11/27/01 09:16AM
  Cylinder IssuesRe: Reeperette Reeperette 11/27/01 11:59AM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 12:06PM
  LoctiteRe: Reeperette Reeperette 11/27/01 05:28PM
  Re: LoctiteRe: don-ohio don-ohio 11/27/01 05:36PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 01:20PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:29PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:33PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 03:38PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 03:54PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:00PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:20PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:22PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:44PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 05:10PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 05:31PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 09:09AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 10:54AM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:23AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 12:15PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:26AM
  Re: 88 TOMOSRe: Reeperette Reeperette 11/28/01 12:50PM
