Tomos Baffle Removal
Reeperette /
On the very end of the exhaust pipe is a cap with a little screw in the side.
Unscrew it, and take a pipe wrench or large visegrips and get a good grip on it - then pull straight out while working back and forth.
If the cap comes off without the baffle, just put the grips on the little tube that was connected to the cap, and repeat above.
Once you get a look at that gunked-up carbon-catcher, you will definately get the point of removing it...also, you will have a slightly more "agressive" exhaust note, which sounds pretty cool.
I wouldn't worry too much right off about gunk and smoke right after a rebuild or repair, cause that happens, but if it continues to happen past about 50 miles, then worry.
When you make repairs, it takes a while for crud, leakage, etc, to burn off, so be aware of that...it's not gonna run flawless immediately even if you disassemble and clean the whole damn works, especially if it's a tomos.
-R
  88 TOMOSTopic by: Mark P Mark P 11/26/01 01:39PM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/26/01 01:44PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 01:58PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:11PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 02:16PM
  Re: 88 TOMOSRe: Ron Brown Ron Brown 11/26/01 02:32PM
  Re: 88 TOMOSRe: RogNC RogNC 11/26/01 09:31PM
  Re: 88 TOMOSRe: XBrandon EdgeX XBrandon EdgeX 11/26/01 04:30PM
  Re: 88 TOMOSRe: Mark P Mark P 11/26/01 04:51PM
  Tomos Baffle RemovalRe: Reeperette Reeperette 11/26/01 05:03PM
  Re: Tomos Baffle RemovalRe: Mark P Mark P 11/27/01 09:16AM
  Cylinder IssuesRe: Reeperette Reeperette 11/27/01 11:59AM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 12:06PM
  LoctiteRe: Reeperette Reeperette 11/27/01 05:28PM
  Re: LoctiteRe: don-ohio don-ohio 11/27/01 05:36PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 01:20PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:29PM
  Re: Cylinder IssuesRe: Ron Brown Ron Brown 11/27/01 02:33PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 03:38PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 03:54PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:00PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:20PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 04:22PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 04:44PM
  Re: Cylinder IssuesRe: Mark P Mark P 11/27/01 05:10PM
  Re: Cylinder IssuesRe: don-ohio don-ohio 11/27/01 05:31PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 09:09AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 10:54AM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:23AM
  Re: 88 TOMOSRe: don-ohio don-ohio 11/28/01 12:15PM
  Re: 88 TOMOSRe: Mark P Mark P 11/28/01 11:26AM
  Re: 88 TOMOSRe: Reeperette Reeperette 11/28/01 12:50PM
