<HTML>I've been considering trying it. Do you guys think it will work?
I'm going to remove the carb, and replace it with a piece of PCB plastic pipe. Then I'll mount the fuel injector through the side of the pipe. That way air still flows normally, but you can add as much fuel as you want at any given RPM.
I haven't figured out how to run the fuel pump yet though, and how to control how much fuel gets injected.
Does anyone know how those injectors work? Are they voltage controlled or something?
Even if I did all of this, would I get enough power to be worth it?</HTML>
