<HTML>i m new to this moped stuff what dose the switch on the right handle bar next to the accerator do it goes up an down but i have no clue all i know isthat it needs to be in the up position to start up ?
joe whalen</HTML>
joe whalen</HTML>
<HTML>It might help if I knew the make and model of your ped. Anyway, it should be specified in the manual that came with the ped.</HTML>
<HTML>a puch maxi i bought it off a bud
joe
<HTML>If it must be in the up position to start, it could be a contactbreaker. If your ped stops running when you flip the switch down then I'm pretty sure it is. I'm not familliar with your ped, but my Vespa has something similar. The purpose of a contactbreaker is to be able to kill the engine. On my Vespa it opens up a hole in the cylinderhead so the engine loses compression and dies. Yours could be an electric contactbreaker that cuts the electrics to the sparkplug. Or I could be totally wrong.</HTML>
