Re: If you need to clean the carb ...
Chris S /
Zippy is right. The idle jet can be seen when looking into the venturi from the engine side. It is a small hole in the body of the carb just below and in front of the brass tube that comes from the main jet. If it is clogged, you may not even see it. A telltale symptom is if it will start with full throttle but will not run at idle.
Chris S
  got it to turn over but...Topic by: Dave Dave 11/24/01 01:38PM
  Re: got it to turn over but...Re: XBrandon EdgeX XBrandon EdgeX 11/24/01 01:56PM
  Re: got it to turn over but...Re: Vespalad Vespalad 11/24/01 03:38PM
  If you need to clean the carb ...Re: Zippy Zippy 11/24/01 03:51PM
  Re: If you need to clean the carb ...Re: Chris S Chris S 11/24/01 06:36PM
  Re: If you need to clean the carb ...Re: brian away brian away 11/25/01 11:14PM
  Re: Zippy's Carb pixRe: Jim C. Jim C. 11/25/01 01:06AM
