If you need to clean the carb ...
Zippy /
These pics might help. The carb has an Idle jet that is often missed. Go to this link at look at Vespa Carb Cleaning. You will see the idle jet in Pic # 10. This may need to be cleaned. DON"T drill it out, use a very small piece of wire (strand from control cable) and c\blow it out with compressed air.
Here is the link; http://briefcase.yahoo.com/bwebb08
go to Vespa Carb Cleaning folder
  got it to turn over but...Topic by: Dave Dave 11/24/01 01:38PM
  Re: got it to turn over but...Re: XBrandon EdgeX XBrandon EdgeX 11/24/01 01:56PM
  Re: got it to turn over but...Re: Vespalad Vespalad 11/24/01 03:38PM
  If you need to clean the carb ...Re: Zippy Zippy 11/24/01 03:51PM
  Re: If you need to clean the carb ...Re: Chris S Chris S 11/24/01 06:36PM
  Re: If you need to clean the carb ...Re: brian away brian away 11/25/01 11:14PM
  Re: Zippy's Carb pixRe: Jim C. Jim C. 11/25/01 01:06AM
