After you've pedaled the thing as much as you say, pull the spark plug and see if it is wet with fuel. If the plug is dry, which I suspect it is, then you're not getting gas to the engine.
That's a quick and easy check. The other advice you got is sound. I'll bet the carb is not passing gas (no pun intended).duck wrote:
> Hey gang... I got out the vom like ron suggested and found a
> few problems. a new wire and viola I now have SPARK.....
> however.. Just as I suspected my home made fuel petcock is
> leaking very bad.
> I just took a car brass fitting nipple and screwed it into
> the tank then ran a rubber hose from it to the carb. I
> wasn't sure if it was getting gas so I like an idiot pulled
> the hose off the top of the carb and was instantly soaked
> with gas and about a 1/3 of a tank worth of gas rushed out
> before I could push it back down onto the carb.
> does the petcock regulate the amount of gas going to the
> carb? or does some how the carb regulate itself or how does
> this work?
> I pedeled till my legs were wobbly when I stopped.
> any ideas where I could get the proper fuel petcock or
> regulator or something? would this be a problem or is the
> more gas the better?
> thanks .. duck.
> *****very very excited he finaly got spark!!!****
