Tomos carb
Crisis--Cincinnati /
Is it easy to get a carb out of a Tomos Golden Bullet, top tank? It is an 89'. I was looking at my friends, and he wants to rejet it. But from looking at the carb, and where it is, it looks like you would have to drop the engine to get it out. If that is the case, he probably won't rejet.
chris
Re: Tomos carb
Take the chain loose, take out the 2 top engine bolts and let it drop down... have something ready to set under it so it wont drop all the way... (it may pull on the cables) disconnect the fuel line first. Then you can get to the carb. D.D.
