1980 Puch Maxi Magneto
WesParker /
<HTML>Can anyone tell me what size nut/thread is used to hold the flywheel on......Also can anyone tell me how to put the wheel back on so the timing is correct.. Thanks Alot .......wes</HTML>
RE: 1980 Puch Maxi Magneto
<HTML>The flywheel should go directly on the crankshaft. The crankshaft should have a thread and it should be shaped in a way so the flywheel can only be fitted in one position. On some peds, the flywheel isn't bolted down, it is jammed against the clutch, and the clutch is bolted to the crankshaft. If your crankshaft has no thread, something is seriously wrong, in that case you should fit a new crankshaft, and if you're looking to buy a new crankshaft, get a race-crankshaft. A race-crankshaft is much lighter and will allow faster accelleration.</HTML>
