<HTML>As long as you have the cable disconnected at the wheel, try spinning its' end making sure it is engaged with the speedo head. If the needle on the speedo moves, the problem is with the drive on the wheel. this unit must be replaced. If the cable spins but the needle stays at zero, the square hole the cable fits into the speedo head is stripped. You'll have to get another speedometer.</HTML>
