there is this thing in my moped and the thing in the thing is broken but there is a thing holding the thing in so is there any thing that i can do without taking out this thing with out taking out that square thing that covers this thing? thanks
Take the thing and use a thing on it that has this thing that moves the other thing but not the big thing and do a thinglike action with it so that the thing does this thing that's not unlike the thing that a similar thing might do
I couldn't have answered it better Brandon!
I think you've got the doohickey confused with the thing-a-ma-bob. If you loosen up the whatzit and make sure you pull the other thing out of the way it should work even better.
When you are putting the thing back together, you will find the governor attached to the dilithium drive. Theres a plug looking thing with a bunch of wires. Disconnect the regeneration module governor one and put all things you found back like they're supposed to be.
Derestrict the bi Turbo bearings by soaking in Wringer's Lactate overnight (The bearings, not you) and you will have a 55MPH moped.
It's that easy!
Jim
I disagree, but you do have a point! I think it would be easier to buff the wobble pin bushings... but just my opinion.. Doug
that's what I did with my Schwinn 10-speed, strapped a bi-turbo to the handlebars, and I gained about .7-.9 mph when going down hills.
i wired my polaroid into my computer, but i dont't think i'm using the correct software, the pictrues still come out of the camera.
i'll paint flames on my laptop too.
shoot i thought that you were suposed to put the bi turbo on the exhaust of the computer fan duhhhhh
yes, i thing so,
I will lone you my 4# hammer, that is what it takes.
<IMG src="http://animatedgif.net/beavisbutthead/mooning_bart_e0.gif">
you guys need to quit playing with "things".... man
Joey,
I keep repeating this and obviously you are not listening.
You must post the year and model of your ped, and an explaination of how the problem started.
Is this a ped that has not run for a long time, did it gradually develop this problem, or was it sudden?
Without this info, we will not be able to help.
Ron
LMAO
harharharhahahahaheeeee,
GREAT POST!!!!
Get a widget and put it over the thing that is beside the thing that covers the thing and squeeze the widget until the thing can wobble enough to slide a watchamacallit into the area that the thingy ocupies. Once you have succeeded in doing this, get a manuel and place it under the bike to catch any of the slippery fluid stuff that might poor out of the square hole that you will now be placing the round peg into.
Jamie
Be very careful not to disturb the plasma coil injectors when removing the dilithium crystals. The phase inverter could be disrupted causing a total shutdown of the engine core.
LOL!!!!!
You are all a bunch of goofy bastards, you know that?
Vespa,
Thank you, thank you very much.
That is the nicest thing anyone has ever said about us!
We're just trying to help.
"....Those Goofy Bastards are the best thing that ever happened to me...."
Matt Dillon (Something about Mary)
