RE: Honda Spree Starting Trouble
Bret /
I had the same problems with my spree. I would start it up and it would die right away. I cleaned the card and i cleaned the air filter and nothing seemed to work. So then i thought it was the the choke, so i toke the choke off and started it up, so i could see if the choke was working. So just for the hell of it, I disconnected one of the choke wires so it would disable the choke. Then sure enough it started like new, it takes about 2 minutes to warm up properly, and then its good to go. I'm not sure if you fixed your scooter yet, but if you haven't try this, it may work.
  Honda Spree Starting TroubleTopic by: Ian Ian 05/06/00 10:53PM
  RE: Honda Spree Starting TroubleRe: Ivo Ivo 05/08/00 12:55PM
  RE: Honda Spree Starting TroubleRe: Ian Ian 05/08/00 09:49PM
  RE: Honda Spree Starting TroubleRe: Ivo Ivo 05/11/00 04:47PM
  RE: Honda Spree Starting TroubleRe: Bret Bret 08/14/00 12:50PM
