RE: Moped won't run unless accellerating
Bill /
<HTML>what you might want to look at is a complete cleaning of the carb., the idle circut/orifice is cloged with rust/gas varnish & other nasty crud. If its running fine when you open the throttle up you DO NOT have a compression problem, the engines not getting any gas.</HTML>
