Re: what's wrong with my carburetor?
Crisis--Cincinnati /
Jon, Did you switch the whole carb out, or just the bottom part? If you just switched the bottom part, and left the choke slide and needle, spring, from the old one, it is possible that the new carb is bigger, and you will need to use the same choke slide and needle that it originally had. Just a thought, because that is what happened to me when I switched out my carb. I didn't feel like taking the throttle cable off, so I half assed it, and tried to use the same slide and needle from my old carb, on my new one. I had the same problem as you, when I did this. My bike idled at Mach 10 and ran like shit. There was too much fuel getting in because the choke slide was not big enough. There's my two cents.
  what's wrong with my carburetor?Topic by: Jon Dalton Jon Dalton 11/12/01 06:23PM
  Re: what's wrong with my carburetor?Re: miguel miguel 11/12/01 08:47PM
  Re: what's wrong with my carburetor?Re: Ron Brown Ron Brown 11/13/01 11:01AM
  Re: what's wrong with my carburetor?Re: Crisis--Cincinnati Crisis--Cincinnati 11/13/01 12:42PM
  Re: what's wrong with my carburetor?Re: Jon Dalton Jon Dalton 11/13/01 02:11PM
  Re: what's wrong with my carburetor?Re: miguel miguel 11/13/01 04:53PM
  Re: what's wrong with my carburetor?Re: Crisis--Cincinnati Crisis--Cincinnati 11/13/01 06:46PM
